McSkinner Posted March 26, 2004 Report Posted March 26, 2004 So I was installing my motion pro throttle kit last night, and I think I may have drilled and tapped the wrong side of the carb. when mounted, the idle screw will be on the inside of the bike. Anyone know what I mean? Quote
fixitrod Posted March 26, 2004 Report Posted March 26, 2004 Uh oh Guess your gonna have to use some jb weld or get some new carbs. Actually, since you probably alread tapped them, you could get a short screw and loc-tite it in place. The loc-tite will make a seal and keep the screw from backing out. You should have drilled and tapped the hole that has a slang on it... on the outside of the carb. Then you have to file the slant flat. Actually, file it down a little extra so the idle screws will go in far enough. Good Luck Quote
banshdog Posted March 26, 2004 Report Posted March 26, 2004 think you should be aliright if you pur a short screw in there to seal it off. Quote
banshee tuner Posted March 28, 2004 Report Posted March 28, 2004 Someone didn't follow instructions did they? I'm just joking it could happen to anyone. Quote
