doltz Posted March 24, 2004 Report Share Posted March 24, 2004 What is the best method to redo stock a arms? I think the heat of a powdercoating oven would crack the ball joint??? Quote Link to comment Share on other sites More sharing options...
Foobie Posted March 24, 2004 Report Share Posted March 24, 2004 I pulled the boots on the ball joints, wiped them off then tapped them off. Sandblasted, primed, and painted. I then put the boots back on with little zip ties. No problems yet. Came out great. Dustin Quote Link to comment Share on other sites More sharing options...
checkster Posted March 24, 2004 Report Share Posted March 24, 2004 if your careful you can remove the ball joint boot retainer and reuse them, I have. check Quote Link to comment Share on other sites More sharing options...
wansomordis Posted March 24, 2004 Report Share Posted March 24, 2004 I had my bottom stock ones powdercoated... One ball joint got melted so had to have another one done... I then drilled the bottom of them and put in a grease jerk to fill them back up..They have been on for about 2 years and are nice N tight.. However If I had known that at that time I probably would have just painted them..(I was a lucky one)...Oh I just resued the metal retainer thing too Quote Link to comment Share on other sites More sharing options...
