This may be in the wrong forum, but it's not really a repair or mod. Can some body please tell me how many links I will need with a -2 length swingarm. My little brain obviously can't use the search right, I can find everything except for what I'm looking for. Thanks in advance
broke
I had to take three complete links out when I installed mine. Some people need to remove four. So you should double check before you start cutting it apart. First separate the chain so that it is no longer a loop. Then set the rear axle in the middle of its adjustment and lay one end of the chain on the rear sprocket. With the chain looped around the front sprocket see how much the second end of the chain overlaps the first end. This is how much you'll need to remove.
