yamahajunky38 Posted March 21, 2004 Report Posted March 21, 2004 how do i drain the gas tank on my warrior, i got water in it. any advice would be helpful thanx Quote
ranshee Posted March 21, 2004 Report Posted March 21, 2004 Take the tank off the bike. Pour out the gas and clean it out with some carb cleaner or something that will evaporate. Quote
yamahajunky38 Posted March 21, 2004 Author Report Posted March 21, 2004 Just put dry gas in it. i tried that and it didnt work Quote
yamahajunky38 Posted March 21, 2004 Author Report Posted March 21, 2004 Take the tank off the bike. Pour out the gas and clean it out with some carb cleaner or something that will evaporate. is there any other way then takin the tank off of the bike???? Quote
BansheeJerry Posted March 21, 2004 Report Posted March 21, 2004 Turn the fuel valve off,disconnect the fuel line from the valve,then open the valve to the reserve position. You can drain the tank that way. Alot easier than removing the whole tank. Thats the way I drain mine. Quote
frocashmoney24 Posted March 21, 2004 Report Posted March 21, 2004 to get EVERYTHING out, your gonna have to take if off the frame, popping off the fuel line and drainig it will get most of it out, but some water may still stay in there Quote
yamahajunky38 Posted March 21, 2004 Author Report Posted March 21, 2004 thanx 4 all the help its greatly appreciated Quote
