the bolts all require different torque specs. i suggest you buy a clymer manual.or visit.
www.thebansheezone.com
i m pretty sure meat has a torque spec. chart type thingy.
You should torque all the bolts/nuts on motor.
head bolts --20 foot pounds (MAKE SURE YOU TIGHTEN THEM IN THE RIGHT ORDER)
cylinder nuts--20 foot pounds
case bolt are tightened in four steps--
upper bolts 43 inch pounds,then lower bolts 86 ich pounds,then upper 18 foot pounds,then upper 86 inch pounds
If you don't have a Clymer manual I would get one.It will make you rebuild a lot easier.
start from the center and work your way out. only torque about half the spec then repeat steps completing torque spec. don,t quite remember but stock head might have the number sequence on it.
