LIsurfer_ Posted March 19, 2004 Report Posted March 19, 2004 I am putting on a new set of razrs 22/11/9 and am wondering what would be ideal pressure for hard packed m/x track. Thanks in advance Quote
MotulMonsta Posted March 19, 2004 Report Posted March 19, 2004 Fronts or rear tires? 22's a bit big for the rear...anyways run the fronts at no less then 10 psi and no greater then the max allowed on the tire. Run the rears at 3-5 psi..but if you got 22's on the rear I'd bump that to 7 or 8 psi cause those baby's will roll in the corners and not want to slide. Quote
Foobie Posted March 23, 2004 Report Posted March 23, 2004 When I ride MX I usually set the front up at 10-12 and the rears at 5-9. I have Holeshot MX fronts and MXR rears. those baby's will roll in the corners and not want to slide. Dustin Quote
MotulMonsta Posted March 25, 2004 Report Posted March 25, 2004 Here's a good tip...The harder the dirt, the higher the tire pressure. Quote
