I need help!! I whipped my whole computer one day and the one thing i forgot to save was the pics i took of the quad. If someone could take some pictures of everywhere the wiring goes and where everything mounts it would help me a great deal. Thanks -JOE
Joe the wiring can pretty much go where you want it. i was goign to run mine in the frame , but couldnt find any long enough heat shrink on a sunday so i said screw it. anyways, i dont have pics, but running the wires are pretty easy. start at the back and istall the cdi box on the left and the voltage regulator on the right.then run the wires up the right side of the frame. then you should be able to connect the wires from the engine for the stator, then run them up to the coil and plug your off and on switch in, the ones for the lights and all the tors can be left off, unless you are going to use the lights.
Another fool without a service manual. <_<
watch it boy no need for stupid insults, and thanks Clint. The reason i do not have a service manual is because im waiting for my dealer to get it in. But i want to have it done.
Sorry, didn't mean to sound so insulting. I had just replied to several questions that all were easy lookups in the manual, not that I don't want to help, but there's no way for me to explain them as good as the manual can, especially with wire routing.
Scott
