Otis Posted March 11, 2004 Report Share Posted March 11, 2004 This is the set up i believe will work best....tell me if you think this sounds right, or what i need to do different. elevation: 2030 ft riding type: mostly dunes (95%) pipes: FMF fatty w/ pc II's avg. outside temp: 60-80 F This is the set up i came up w/ mains: 320 Pilots :27.5 needles: stock setting air screw: 1 1/2 out If i left anything out, or you think i need to change something, please let me know Thanks... Quote Link to comment Share on other sites More sharing options...
Schizo Posted March 11, 2004 Report Share Posted March 11, 2004 I donno how big of air whores FMF pipes are but that sounds really close. Quote Link to comment Share on other sites More sharing options...
sredish Posted March 11, 2004 Report Share Posted March 11, 2004 This is the set up i believe will work best....tell me if you think this sounds right,or what i need to do different. elevation: 2030 ft riding type: mostly dunes (95%) pipes: FMF fatty w/ pc II's avg. outside temp: 60-80 F This is the set up i came up w/ mains: 320 Pilots :27.5 needles: stock setting air screw: 1 1/2 out If i left anything out, or you think i need to change something, please let me know Thanks... That sounds pretty close, depending on if your airbox lid is on or not and what kind of filter your using. If the lid is on, you might be a tad rich on the main at your elevation. If it's off, you'll be real close, and good baseline to start at. I don't remember what the stock setting for the needle is, but I would have it in the 3rd clip down at very minimum, maybe even 4th, though that might be a tad rich at your elevation. Only one way to find out, and they are simple to adjust. Quote Link to comment Share on other sites More sharing options...
Otis Posted March 11, 2004 Author Report Share Posted March 11, 2004 I knew i was forgetting something(air box lid / filter) no lid and Pro-Designs w/ K-n-N set up.. Thanks for the input! Quote Link to comment Share on other sites More sharing options...
Ducman Posted March 11, 2004 Report Share Posted March 11, 2004 Your jetting sounds good to me. Quote Link to comment Share on other sites More sharing options...
Banchetta Posted March 15, 2004 Report Share Posted March 15, 2004 I did a quick jetting on Yammahammers quad at Dumont w/ pretty much the same setup....300 mains, stock pilots, air screws 2.5 turns out, needles at the 5th clip from the blunt end if you have stock reeds, 4th clip if you have aftermarket reeds..... Quote Link to comment Share on other sites More sharing options...
