i just got this bike on trade. it runs fine, and shifts fine under normal use, but when i try to drag, i struggle to hit 3rd and 4th. i can't accelerate fully and go through the gears, i have to let off for it to fall in to gear. any suggestions, i dont know where to start. thanks
As long as your clutch is good, I would also start with the oil. I use silkolene light comp oil and have really good luck. There are tons of different oils to use, try several and see how it goes.
HEY GUYS IF YOU READ YOUR CLYMER MANUAL YOU HAVE ADJUSTMENTS ON YOUR SHIFTER IT'S ON YOUR CLUTCH SIDE OF THE BIKE. MY BIKE DID THE SAME THING TILL I ADJUSTED IT.
It could be a number of issues. Clutch adjustment like ol dude above me said or the internal forks and grooves on the cam are worn. Also the dogs on the graes could be worn. My shee has issues going into third. But it's a beat on old 87 motor and everything inside it is worn.
new oil does alot for shifting! other than that banshees dont shift well stock, I cant tell if you problem is something wrong or just the usual shiftng problems.
Why not get the shift star machined ?? I've heard there are a few on here that can do it or send it somewhere like duncan racing (25.00) .. It takes pressure off the detent spring which helps shifting from gear to gear..Also helps finding neutral when you are using heay duty clutch springs.. Just a thought
Shift star mod. You can send it off or do it yourself on the grinder (harder to back-cut neutral that way though). Mine had the exact same problem, I had to let all the way off to get it to go into gear when drag racing. The shift star mod seems to do the trick.
Thanks, everyone for the info. I changed my oil, and found it a little low. I run motul transoil 10/30, because thats what the dude i got the bike from suggested. It seems to shift noticable smoother, but i have yet to get it to the beach to see if its really better. I also got a hold to Boonman, and i think I'll send my shift star up to him. Dub
