03 ORANGE SHEE Posted March 6, 2004 Report Posted March 6, 2004 what is the oem part number for the clutch plates(fiber), i was recomended to use this one, 4h7-16321-02,mine wont shift under a load,and i use a dirt digger clutch,my engine porter told me all the problems with it not shifting under load is from that aftermarket kit,and the trans is all new,down to the bolts!! Quote
Creole Posted March 6, 2004 Report Posted March 6, 2004 Try here. http://216.37.204.206/alba/Yamaha_OEM/YamahaATV.asp Quote
03 ORANGE SHEE Posted March 7, 2004 Author Report Posted March 7, 2004 alba does not give part numbers,same goes for troy racing in ohio,thanks though Quote
bigwill Posted March 7, 2004 Report Posted March 7, 2004 I weigh about 280lb-talk about a load-all I run are aftermarket fibers including Barnets-no problems in 5yrs.Your porter is making me nervous!!!!!! Quote
FadedDreams Posted March 7, 2004 Report Posted March 7, 2004 Put the item in your cart and it will take you to check-out and it will show the part number there. Quote
