xt45 Posted March 6, 2004 Report Posted March 6, 2004 for every 1 gallon of gas, put 4 ounces of yamalube (recommended) 1 gallon=128 ounces(oz) 20:1 will be 128/20=6.4 ounces of yamalube per 1 gallon of gas 32:1 will be 128/32=4 ounces of yamalube per 1 gallon of gas 40:1 will be 128/40=3.2 ounces of yamalube per 1 gallon of gas how many ounes per gallon, will be the best for the engine, performance. Quote
MotulMonsta Posted March 6, 2004 Report Posted March 6, 2004 The less oil you run..the more power you make...BUT the lube that motor is getting is what your mixing in that gas...also the oil compresses less the air so the more oil you run the higher compression you'll get. So what's worth more to you? Engine longevity or performance. I used to run 40:1 but after s few years my crank bearings were worn out. Since then I run 32:1. Yamaha recomends a 28:1 ratio. All depends on what you like to do. People run as much as 50:1 but they're doing engine damage in the long run. That little bit of oil you mix in is all the lube that motor is getting remember that. 32:1 is a good ratio has a good ballance of performance and engine life. Quote
xt45 Posted March 6, 2004 Author Report Posted March 6, 2004 20:1 will be 128/20=6.4 ounces of yamalube per 1 gallon of gas 28:1 will be 128/28=4.6 ounces of yamalube per 1 gallon of gas(Yamaha Recommends) 32:1 will be 128/32=4 ounces of yamalube per 1 gallon of gas 40:1 will be 128/40=3.2 ounces of yamalube per 1 gallon of gas 50:1 will be 128/50=2.6 ounces of yamalube per 1 gallon of gas So since Yamaha recommends 28:1 for Banshees, then use 4.6 ounces of Yamalube per 1 Gallon of Gas So using 28:1, for 5 gallons of gas put 23 ounces of Yamalube for best longitivity of your shee. 128*5=640/28=23 Quote
DIRTBIKEZ Posted March 6, 2004 Report Posted March 6, 2004 There are guys here running 100:1 and have been doing so for a long time w/o any problems. Quote
xt45 Posted March 6, 2004 Author Report Posted March 6, 2004 20:1 will be 128/20=6.4 ounces of yamalube per 1 gallon of gas ( Best Longevity ) 28:1 will be 128/28=4.6 ounces of yamalube per 1 gallon of gas ( Yamaha Recommends ) 32:1 will be 128/32=4 ounces of yamalube per 1 gallon of gas 40:1 will be 128/40=3.2 ounces of yamalube per 1 gallon of gas 50:1 will be 128/50=2.6 ounces of yamalube per 1 gallon of gas 100:1 will be 128/100=1.3 ounces of yamalube per 1 gallon of gas ( Best Performance, Worst Longevity ) Quote
brugal Posted March 6, 2004 Report Posted March 6, 2004 Oh boy,here we go.Alot of people run different ratios.Do a search ,so you can loose your mind reading the different posts. Quote
Meat Posted March 6, 2004 Report Posted March 6, 2004 People run as much as 50:1 but they're doing engine damage in the long run. 4 years of 50:1 in mine and the top end looks brand new. I have the head off right now and took some pictures a few days ago. The pistons look like I installed em yesterday and the cylinder walls show some very slight wear marks, the marks in the cylinder walls are so slight you can barely feel the worse wear mark... this is after 4 years of 50:1, and there's 20 other guys here running high mix ratio's with quality premix that have similar results and the proof to back it up. I'll post my pictures asap. BTW when I built my engine and got it broke in, the compression was 140, 4 years later.... its at 135 in both juggs. Kinda pissed me off cause I was hoping to rebuild the engine just to freshen it up and have peice of mind that the topend was fresh for this year, when I did my comp test and seen im at 135..... iv decided to keep running it for a little while longer. Im plannin on rebulding right before CoalFest in July.... just for the sake of retireing the topend and having a fresh one for CoalFest. BTW im using Amsoil premix Quote
xt45 Posted March 6, 2004 Author Report Posted March 6, 2004 how about 1:1, for 1 gallon of gas, use 1 gallon of yamalube, this way your shee will last forever. your opinion please Quote
brugal Posted March 6, 2004 Report Posted March 6, 2004 how about 1:1, for 1 gallon of gas, use 1 gallon of yamalube, this way your shee will last forever. your opinion please Are you serious,please tell me your joking?Why dont you just put diesel??? Quote
Dune Ratt Posted March 6, 2004 Report Posted March 6, 2004 Please understande if you are running Yamalube in you shee you are missing out. Of coures Yammaha wants you to run 28:1 of Yamalube, they are making a bundle of $$ off those of you that are using their product. The more you use the more you buy the more $$ in there pocket and the slower you go. Switch to a synthetic premix and dump the Yamalube it is garbage. Personaly I'm with Meat run Amsoil at 50:1. I've done this ever since I finished breaking the top end in back in 2000 and the Shee runs just as hard as it did brand new and the top end still looks factory. Quote
xt45 Posted March 6, 2004 Author Report Posted March 6, 2004 So what is the minimum ratio and the maximum ratio Quote
Dune Ratt Posted March 6, 2004 Report Posted March 6, 2004 The min and max is totally up to you. Don't go past 100:1 Quote
xt45 Posted March 6, 2004 Author Report Posted March 6, 2004 Well right, Yamaha recommends 28:1, can I do a better job to my engine by doing say 20:1, see wa am sayen Quote
Dune Ratt Posted March 6, 2004 Report Posted March 6, 2004 If you put that much oil in you are going to foul plug after plug and your shee will run like shit. Quote
