bansheeman_95 Posted March 5, 2004 Report Share Posted March 5, 2004 well the tittle pretty muck explains it but my banshee is not getting any spark at all...i tried two different sets of plugs also. the TORS is also unhooked Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted March 5, 2004 Report Share Posted March 5, 2004 Time to check your wiring. Pay close attention to each connection. Make shure your key is on(If you have one) and tether switch plugged in(If you have one). Sometimes it's simply somthing overlooked. Quote Link to comment Share on other sites More sharing options...
TREELIZARD Posted March 5, 2004 Report Share Posted March 5, 2004 if its not your plugs or wiring then you will want check your stator. Quote Link to comment Share on other sites More sharing options...
bansheeman_95 Posted March 5, 2004 Author Report Share Posted March 5, 2004 well all the wiring is fine exept one wire on the rear of the machine, a solid black wire....maybe a ground to something? and how would i go about checkin the stator? thanks Quote Link to comment Share on other sites More sharing options...
my nephews shee Posted March 8, 2004 Report Share Posted March 8, 2004 i would also know how to check stator my nephews just lost spark also what is the tors and where is it please help when i kick it over the lights light up what does the stator control all elec or just spark Quote Link to comment Share on other sites More sharing options...
TREELIZARD Posted March 9, 2004 Report Share Posted March 9, 2004 i'm not exactly sure how to check the stator to see if its bad or not, but i do know that if you have new plugs and your wiring is all good with everything connected then it is possible that your stator can be bad. maybe if you contact your local yamaha they can tell you how to check it or start a topic under general discussion about how to test to see if your stator is bad. sorry that i couldnt have been of more help. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted March 9, 2004 Report Share Posted March 9, 2004 how would i go about checkin the stator? 1st, get yourself a Clymer's manual. 2nd, you'll need an OHM meter. Quote Link to comment Share on other sites More sharing options...
