bansheeman_95
Everything posted by bansheeman_95
  1. there is a little thingy on each carb thats looks like there should be a tube coming off of it. its right on the top of each carb beside the choke. what is it and what is it for?
  2. i didnt see anything about the keihin 28mm's on that site
  3. can anyone give me an idea of where to start with the jetting on the keihins 28's? the jetting in my stock carb was 280 main needle on 2nd clip down and stock pilot. let me know if u need more info. thanks for any help
  4. can anyone give me an idea of where to start with the jetting on the keihins 28's? the jetting in my stock carb was 280 main needle on 2nd clip down and stock pilot. let me know if u need more info. thanks for any help
  5. i figured out why my banshee is running like crap under 1/4 throttle. the little pin things that go into the side of the carbs that keep the slides in and keep them from turning is missing. i called the shop and the part didnt come up in the micro fiche. they also said to try to make one. what should i do?
  6. well all the wiring is fine exept one wire on the rear of the machine, a solid black wire....maybe a ground to something? and how would i go about checkin the stator? thanks
  7. well the tittle pretty muck explains it but my banshee is not getting any spark at all...i tried two different sets of plugs also. the TORS is also unhooked
  8. my bearings just went out for the second time. should i just replace them again or get a duel row carrier?
  9. who stole that ladies other sock!?!?!?
  10. hey man dont u know that the majority always wins?
  11. have u read some of the stupid stuff he has said????
  12. good idea bansheeboy
  13. how many of ya have ran from the popo??
  14. my freind has 35's on his banshee every once in while. (he cant get to my house with them on unless he caries extra gas) when he uses them they make a big difference on top end power.
  15. banshee's dont like that thick stuff. you should use regular motor oil designed for a wet clutch.
