Go to your local dealer and get a new o-ring, spring, and ball. Then take the kicker apart, clean the parts, and put it back together with plenty of high quality grease. You will be good to go for about $5.
Get ahold of holyman here on the site.He rebuilds them.I don't know what he charges but I do know everyones he has done so far love it.I'd say it's worth it what ever it is.
I just spray some WD40 on it once in a while. You could also grease it.
WD40 is a great temporary spray. But after a little while, it will promote moisture and cause things to tighten. The very best spray to use as a long term lube is Silicone Spray Lube. The kind I use is made by Loctite. It keeps moisture out and lube in.
I have a construction company and often times, people will call me regarding the barns i build and say they can't open the feed doors (it's a piano hinge). Well, they've been spraying WD40 in them and they loosen, but after a day or so, they become damn near unmovable, because moisture has gotten in there and locked it up. I will spray the silicone lube and they'll be perfect forever. I give them the spray bottle I take there so they can use it later. Great stuff.
Silicone spray lube huh? I used to use a lot of teflon lube..works great on o-ring chains. But I'll have to try this silicone stuff.
Spraying the ball aint gonna do it. It won't fold out because the stock ball has either a flat spot in it or has worked the retention hole too big and the ball sticks out too much. You need the Holyman rebuild :)
I guess I do. I can't have the bike down right now though so I will suffer until its too hot to ride. Just got it going and if the rain would stop I'd be out riding today....
Thanks guys.
