sredish Posted March 3, 2004 Report Posted March 3, 2004 I'm figuring on a new top end this summer, when time permits. I'm gonna do some porting and I was thinking about a stroker crank, but don't think the money's going to be there. A friend mentioned a big bore kit. I found the Pro Cross 409 big bore kit. What are the drawbacks to this? I was told when it wears out, replace it with a new sleeve, doesn't sound bad. Nice bore size using a 68m piston. How about overheating, don't have a problem now, but don't want one. Will it work with the Coolhead I have now? Big bore domes? The price is very correct and it gives me the chills thinking about it, but need to know more details. Also, what about adding the stroker crank later to the big bore? Please feel free to add any info you know but I didn't ask. Thanks. BTW, I'm ordering my axle this Thurs. so thanks for the help on my other post. Quote
Leadfoot350 Posted March 3, 2004 Report Posted March 3, 2004 Going with a big bore kit will make your tranfers in your cylinder too small. Some run good and some dont run worth crap. You might want to look into getting a crank instead. +7 is the biggest you can go with stock cylinders and that combo works really well. Quote
sredish Posted March 3, 2004 Author Report Posted March 3, 2004 Going with a big bore kit will make your tranfers in your cylinder too small. That's what I was afraid of. Hmmmmm. Quote
sredish Posted March 4, 2004 Author Report Posted March 4, 2004 Anybody else think that there will be a problem running the big bore sleeve? I'm probably going to be adding a big radiator, which will help a lot. I'm pretty sure I'm going to give it a try good or bad, but want some experiences or opinions. Scott Quote
brugal Posted March 4, 2004 Report Posted March 4, 2004 MEAT runs vitos big bores and loves them.You might want to give him a holla,if he doesnt come in here first ,or check his website www.thebansheezone.com Quote
