I have the Graydon Proline 2 into 1 setup (a good friend of mine makes them for graydon, so I got it through him) with a kehin PWK 35mm air stryker. The inside of the manifold has been "spiral flutted" for increased fuel atomization, and we added a special set of reed spacers port matched to the manifold to better direct the increased flow to the reeds (this was all done on a flow bench to track CFM) My engine is a 370 long rod (IMS hot rods, wiseco superlites, proto-type needle bearings on the trued and welded crank), hinson basket, pressure plate, 8 pack clutch set up, agressive dune port for the cylinders, head cut 90 thousandths and re-chambered, pwr radiator, warp drive temp guage (bike runs at 160-180 deg F) with Matt Sheer pipes / silencers specifically made for the engines spec's, 14" long by 4" OD K&N air filter (same one Dennis Packard uses) I run VP 110 fuel mixed at 40:1 with ipone fully synthetic oil. The bike runs extremly strong from top to bottom, made 64 HP, and 52 LB / FT of torque on the dyno, jetting is a snap, tuning is super easy. The engine was built by Kevin Kohrell at Custom Creations ATV in Yucaipa, CA. Gearing is 13 / 41 I run 20x11x10 8 paddle sand stars on a +4 swingarm with a TCS rear shock. I've posted pictures of the pipes and carb/intake setup before, but if you want to see them again let me know. Ask wallrat about his impression of the bike, he rode it for a bit at Glamis over presidents weekend.
I have a bike with T-5's, all stock except for some bolt on stuff, see sig below, and a ported polished bike with CPI's, see that below as well. The CPI's and T-5's sound very similar. The CPI's seem to rev out a bit more than T-5's. My one suggestion is if you are going to or already have your bike ported, get the CPI's, if not and no porting is in your future get the Toomeys.
