When I shift from neutral to first gear, it dies. Unless I give it a little throttle. Then it stays running. First I tried to adjust the clutch cable and then the adjustment inside the case. No better. So I put in a new clutch, on the advice of the local shop. Readjusted it. And it still has the same problem. What is going on? Do I need a new cable?. Any advice would be hrelpful. Thanks
