Hockey390 Posted February 21, 2004 Report Posted February 21, 2004 I was surfing the web and came across some dye made for your coolant. I was thinking to myself, a glow in the dark dye would look bada$$... So I started my search out and was unable to find anything.. So what do you all think? Is there such thing as a glow in the dark dye? If there is, is it safe to put in your radiator? THe reason I ask this is because in order for it to glow, it obviously has some type of chemical, and that makes me wonder if having that chemical running through your engine and all that good stuff would be a good idea or no.. Lets hear what you think. Quote
tithead Posted February 21, 2004 Report Posted February 21, 2004 why would you want it in your radiator? if i was to get it id paint the outside of the radiator cos i thot the hole point is to see it. i suppose it would be goo cos you would see how much water is needed to put in but apart from that.....why? id want it on the outside Quote
orion6781 Posted February 21, 2004 Report Posted February 21, 2004 If he has clear radiator hoses you would see it through them. That would look badass. but i would call the company to find out whats inside of it that makes it glow. Quote
evil Posted February 22, 2004 Report Posted February 22, 2004 if you want that glowing effect, just zip tie a crack and glow stick under your gas tank i wouldnt put anything like that in my rad., if you do, do alot of research on it to make sure it wont mess anything up in there. it is possible they have something, the regular dies they have with the clear hose kits must not harm anything. but who knows Quote
Justintoxicated Posted February 23, 2004 Report Posted February 23, 2004 I think it would work, I have clear hoses and I like the look. Using my Blue LED in the pics from the images forum would get it to glow quite nicely. It would glow EVEN more if I had used radiometric blue (ROyal Blue) LEDs which will be available when I get the kits farther along. This stuff makes anything glow in the dark light up like crazy, it will even react with neon colors. I tested a radiometric blue the other day and the affect was amazing. They are not as bright as the Regular blue LEDs sceen in the pictures but the glow affect is definately intensified. Quote
Banshee Bull Posted February 23, 2004 Report Posted February 23, 2004 Has anyone thought about for some cool summer fun take those glow sticks and if you have clear coolent hoses you can pour the gunck in your radiator and circulate the glowing stuff with the coolent if you have enough of it in there. But remeber to filter the stuff before you put it in. Quote
2004LEBanshee Posted February 23, 2004 Report Posted February 23, 2004 I want glow in the dark plastics . Quote
Hockey390 Posted February 23, 2004 Author Report Posted February 23, 2004 But the question is, will the glow in the dark gunk screw up your engine... (some things arent made to run as coolant otherwise I would use glow int he dark gunk as gasoline ) Quote
