monty9 Posted February 21, 2004 Report Posted February 21, 2004 im building a banshee, and i cant get the motor to start. there is no spark at the plugs. this is what i know, the cdi, coil are fine and the other box by the cdi is fine that has the blue wire coming from it. i know these are fine because i had a friends quad here and took the parts off mine and put them on his and it started. i have no clue what to do or were to start, the headlights are lighting up, but that is the only thing going on. any help will be great Quote
cb67rs1 Posted February 21, 2004 Report Posted February 21, 2004 do you have the TORS still on it? if so disconnect all of it and then give it a try Quote
Creole Posted February 21, 2004 Report Posted February 21, 2004 Kill the tors system it is all over this web site on how to do so. Quote
monty9 Posted February 21, 2004 Author Report Posted February 21, 2004 there not hooked up, do i have to do something to them on the main harness Quote
monty9 Posted February 21, 2004 Author Report Posted February 21, 2004 everything with the tors was removed, i still have the plugs on the main harness but the plugs coming from the tors were cut, its realy getting me mad. all the stuff that went to the handles bar are not pluged in, thet thing that gets me is the lights come on when i kick it but i dont get a spark Quote
89'bansheefan Posted February 21, 2004 Report Posted February 21, 2004 hey, are you getting power to the 2 wires that connect to the coil? Quote
tithead Posted February 21, 2004 Report Posted February 21, 2004 check the connection the the plug caps. it could be faulty? Quote
monty9 Posted February 21, 2004 Author Report Posted February 21, 2004 i check the coil on a friends quad and it ran Quote
89'bansheefan Posted February 21, 2004 Report Posted February 21, 2004 Sounds like your coil works, but I don't think power is getting to it on your bike. Check the two wires that connect to the coil with a hand held voltage meter. Quote
neilgf Posted February 21, 2004 Report Posted February 21, 2004 Sounds like a possible problem with the stator on the side that supplies power to the engine as the lights run off a seperate circuit.There is a thread in the repairs and mods forum on how to test it... Hope this helps Quote
monty9 Posted February 21, 2004 Author Report Posted February 21, 2004 how do i take the startor off, i got the cover off and there is a metal plate over the stator, how do i get that off to look at the stator Quote
Creole Posted February 21, 2004 Report Posted February 21, 2004 How about that little button that goes to the gas lever is that disconnected? Quote
zilladude Posted February 22, 2004 Report Posted February 22, 2004 Are the 2 wires for the key switch connected? When they are not connected it is like having the key off. Quote
