Air Borne Posted February 21, 2004 Report Posted February 21, 2004 okI, just bought a used 2001 banshee. It has a pro design coolhead, bysen reeds, k&n single filter, paulturner mid range pipes and fat boy silencers, I live in cheyenne wyoming, the altitud here is 6'100 feet, and i only used it when the temperature is around 60 to 90 deegres. since I bought it I've been noticing that in the top end the engine will not gives all it's power, and I know that with the moods I'm supposed to beat a stock raptor wich i didn't the time we'd raced. Can I get some help???? Quote
locogato11283 Posted February 21, 2004 Report Posted February 21, 2004 you need banchetta to help you. either send him a pm or just wait a little bit and you will get your answer. Quote
03 limitedbansheecustom Posted February 22, 2004 Report Posted February 22, 2004 im from jersey and i putt fmf gnarly pipes wit power core 2 silencers,, i usd the jets that came with the pipes, just swapped em and started it up, ran like a mutha flower Quote
spoin39 Posted February 23, 2004 Report Posted February 23, 2004 What jets are in it now? Does it have a bog anywhere or just doesn't seem to rev? Does it do it in all gears? Give some info so we can help. Quote
Liftedbronco Posted February 23, 2004 Report Posted February 23, 2004 I am actually having the same problem. I just took the airbox cover off and i get some bog wide open on the top end. I dont think this was enough to re-jet...im guessing i just need to adjust something.......how? Im guessin i need some kinda syncronizer like they use on motorcycles. Quote
Big Blue Posted February 23, 2004 Report Posted February 23, 2004 I am actually having the same problem. I just took the airbox cover off and i get some bog wide open on the top end. I dont think this was enough to re-jet...im guessing i just need to adjust something.......how? Im guessin i need some kinda syncronizer like they use on motorcycles. did you rejet if not you are probably lean. Quote
Liftedbronco Posted February 23, 2004 Report Posted February 23, 2004 Didnt rejet. Didnt touch anything, I just bought this thing last week...first quad. lol. I found a nice page here http://www.thebansheezone.com/Bansheezone/AirIntake.htm seems to tell me what i need to know. Im gonan try adjusting the screw today and if that doesnt work, then according to this website, i need to go up a size in my main jet. Quote
Liftedbronco Posted February 24, 2004 Report Posted February 24, 2004 Ok, i put the airbox cover back on and just pulled off the snorkel this time. After that and a little turn of each of the screws atop the carbs....thing runs liek a top again. Quote
fixitrod Posted February 25, 2004 Report Posted February 25, 2004 Ok, i put the airbox cover back on and just pulled off the snorkel this time. After that and a little turn of each of the screws atop the carbs....thing runs liek a top again. That's because you leaned it out by taking the lid off. The best jetting advice anyone can get is here ----> BenBB's jetting faq Quote
