nickxc Posted August 30, 2002 Report Posted August 30, 2002 :?: I put new holeshots and rims on my banshee this spring and I have noticed one of them wearing out a lot faster than the other. I ride a lot of roads and I thought that would be normal because sometimes one tire is on the pavement and the other is in the dirt but it is the one that would be in the dirt that is wearing faster. and I don't let that happen very often. I usually try to keep either both on the pavement or both in the dirt could this have anything to do with my high speed vibration that I mentioned in earlier posts :?: :?: Quote
THX-1138 Posted August 30, 2002 Report Posted August 30, 2002 if one tire has more air PSI than it is bigger and will drag the other tire. other than that maby you got two differint rubber compounds. I have holeshots on my R and they have worn evenly. Quote
nickxc Posted August 30, 2002 Author Report Posted August 30, 2002 I think my air pressure is at least very close. it doesn't pull or anything Quote
'99350t Posted August 30, 2002 Report Posted August 30, 2002 nick, thats on a banshee right? make sure your axle adjusters are in equally far, something is likly bent, mine does that too with my fast trekkers, but my is light that because i screw around on the roads(donuts, burn outs, etc.) Quote
nickxc Posted August 30, 2002 Author Report Posted August 30, 2002 Is there a special way to make sure that my chain adjusters are equally adjusted??? is there something I can measure or something??? Quote
Screamin_Banshee Posted August 30, 2002 Report Posted August 30, 2002 You can measure easily (sp?) all you need is a ruler, or something straight and flat and a tape measure. Place the ruler on the backside (farthest from motor) of the axle, and measure from the swingarm bolt. Do both sides and make adjustments needed....hope maybe this helps Quote
astromybud Posted September 8, 2002 Report Posted September 8, 2002 I found; My holeshots nobbies are alot like Good beer! Neither, sticks around for long! But I ride a lot of gravel roads!!!! 3"crush will cut up any tire.. Astromybud Quote
