How much faster is a banshee with Pro circut Pipes,v-force reeds,Head mod(157psi),Bored 27mm Carbs,+4 Hot Rod stroker, Degree key +7,Lighten Flywheel,andVitos Power Pistons
vs
a banshee with Pro circut pipes,v-force reeds,.35" shaved head,Polished intake ports, dual k and n clamp on air filters,Vitos jet kit, stock 26mm carbs,and a boost bottle
im Assuming that the stroker banshee is faster, what other mods can I do to become faster, thanks
1 million times faster, there are a million other factors you left out like sprocket size, rider weight, rider age, tire size, tpe of oil, type of clutch, type of fuel, type of rider, type of shifter, type of carbs... the list goes on, there is only one way to find out and thats to go out and do it and stop talking about it.
word
wount it still go the same size if teh gearing and sprokets are the same, just get there very fast
you mean speeed instead of size right? Well no, lets take 2 banshees
1 banshee has a fouled plug so its running one one cylinder only
the other banshee has a t-rex kit in it and runs on alcohol
which one do you think will have the higher top speed if both of these bikes have the same sprockets?
this is what I mean when I say different factors
