2001 929 Posted February 8, 2004 Report Posted February 8, 2004 someone if trying to talk me into these and was wondering on suggestions or opinions on these carbs, running CPI's, aggressive trailport, vforce, pwk28 tapered to 30mm, 17 domes Quote
PassionRE Posted February 9, 2004 Report Posted February 9, 2004 34's would be considered all out top-end only on a 350 motor regardless of porting...Jim Quote
banshee370 Posted February 9, 2004 Report Posted February 9, 2004 I'm running the 34TM Mikunis and I love them. They are easy to work on and get jetted in. You may lose some low end throttle response but that would depend on exactly how your motor is set up. I would contact your motor builder and see what "he" recommends. With my current mods I have tons of low end w/ a screaming top.... So I have no complaints Quote
alcoholbanshee Posted February 11, 2004 Report Posted February 11, 2004 34's would be considered all out top-end only on a 350 motor regardless of porting...Jim I run 34mm TM carbs. They are awesome. You will not be dissapointed.As for no bottom end. I run 1.5 60 foot times in sand on a 350 stock stroke stock bore. Quote
PassionRE Posted February 11, 2004 Report Posted February 11, 2004 34's would be considered all out top-end only on a 350 motor regardless of porting...Jim I run 34mm TM carbs. They are awesome. You will not be dissapointed.As for no bottom end. I run 1.5 60 foot times in sand on a 350 stock stroke stock bore. Wow!...those are great times...I imagine your dumping the clutch at or near WOT? Quote
yamaha350 Posted February 11, 2004 Report Posted February 11, 2004 isn't that how you drag race, wot and dump the clutch. i ran 34 tm's and love them. so easy to tune. Quote
rebelbanshee2 Posted February 11, 2004 Report Posted February 11, 2004 edit-posted in wrong spot Quote
