drag-350 Posted February 1, 2004 Report Posted February 1, 2004 does anyone know what to adjust your timing on for nitromethane and are they any advantages if so any info would be appreciated.thanks....... Quote
909 Posted February 2, 2004 Report Posted February 2, 2004 you mean methanol (alcohol)??? Please don't double post. Quote
Dextreme Posted February 2, 2004 Report Posted February 2, 2004 Nitromethane is something that can be added to Methanol. It doesn't mix with gas. I am not sure on the timing, but I know you have to get much bigger jets and there have been plenty of blown motors with people toying with it. I does make lots of HP though when dialed in. Quote
MULLET~BOY Posted February 2, 2004 Report Posted February 2, 2004 i think you mix it like 4% but don't take my word for it you don't want to mix it with gas like stated above you have to be really good at tunning i wouldn't screw with it unless your a really good tuner or your made of money Quote
drag-350 Posted February 2, 2004 Author Report Posted February 2, 2004 i have ran methanol for two years now. i know pretty much how it work's so i thougt i would try nirtomethane i have read a lot about it& how it can be mixed just haven't heard about what to set your timing on....and that was the first time that i have posted anything on here . sorry about that . Quote
MULLET~BOY Posted February 2, 2004 Report Posted February 2, 2004 i would ask on www.planetsand.com there are a few people on there that run it and might be able to give you some info on the timing i run plus 8 with meth i don't think it would be to much off from that probably like 7 or mabey 6 to keep the motor cooler duno though Quote
drag-350 Posted February 3, 2004 Author Report Posted February 3, 2004 i will post it on planet sand and see if anyone can give me some info on the timing.i run my timing on 6 right now maybe all try it like it is.you said you run your timing on 8 i have heard of guys runing a higher timing . but i haven't tried anything more then 6. i will try runing mine on 8 and see if it help me on menthanol. thank's for the info Quote
MULLET~BOY Posted February 3, 2004 Report Posted February 3, 2004 i have heard of people running like + 10 from what i have heard 8 works the best Quote
