I bought a stator and lights off ebay. the thing is I don't think I like the square lights that were part of the auction. I do like the big ass dessert racing lights like on Rick Stators web page etc. but I'm afraid that if I bite it the mega $ lights will get trashed - not to mention if you park lights of that size in front of the rad it's got to effect cooling. So what do you all recomend that puts out huge light. It's a 200 watt stator so I have to work within that range of power.
I had those big ass chrome plated banshee desert lights by PIAA, I would buy them, use 55W bulbs, they work best, stock 35w bulbs work great as well. BUY them lightS!!!! If you eat shit, worry about breaking your bones, eveything else you can replace on EBAY.
Bajadesigns sells some lights you might be interested in. They are a little pricey but they are the bomb if you are serious about riding. You could run either a dual or singal halogen or HID setup. The HID take less power and makes a lot more light. Check out this site lights
here are the lights i put on the shee saturday 1-24-04 i used a piece of 1/2 inch round tube and a mounting tab then welded then together and used the light stud as a block from the lights going down
those are 9" hella's not blockin that much of the rediator.
the mounts are pointed downwards and i make up for the down with the light adjustments.
hope this helps one is 55 watts and the other is 100. and just bought a new ricky stator 200 watt stator and regulator should be here thursday. thses lights are in the stock location using the stock bolt.
Looks great. So do you have to get a different regulator ? I have no idea if a non stock one comes with the stator I bid on cause it isn't here yet. why did you go with a 55 and a 100 watt rather than both 100's - just so the stator isn't working so hard or lighting pattern ??? Oh ya like your avitar to B)
ya so i am not pushing the limits and then i can still have a low and then both as a high. i am also looking to get the underlighting that justintoxicated is making so i still have a few extra watts if i wanna do something different i can. ricky stator says you can use the stock one but it could possibly fail for 20 buck extra i said give me a new one.
Sorry my reply took so long but I had to get my bike back together before I could take the pictures of the mounting. Here's how its setup - keep in mind that I bought the bike this way so I have no idea how different this mount is from stockers...
Oh and as a side note, I've got a buddy with the same lights that he mounted with a handlebar mount on his 250r. It looked to be your typical ricky stator or baja designs type of handlebar mount.
