i would like to know where online i could but a case saver and the bolt to hold on the sprocket....here is why........i worked on the shee, she is running the best ever, but i took her out today for the first time in like a month cause she was crippled, and the nut holding on the sprocket fell off:(, and i lost it, but i found the sproket, i was wounering why did it fall off, casue i put it on tight, i dont wanna always have to worry about it casue it happened twice now:(
Probably gonna have to go to the dealship to get the nut.There should have been a big washer that you fold the edges to hold the nut in place.I know when i took mine off,the nut was loose,but the washer kept it from coming off.Maybe i just lucked out and caught it in time.You can go to the site below to get what you need.
Ronnies Online microfiche
if your that worried about loosing it a 3rd time get a new nut,fold down the sides of the washer,you do have an over sized washer dont you,til it touches the sides of the nut.that will keep the nut from spinning loose kinda works on the same principle as safety wire.or you can put some loktite blue onto it.ebay for the case saver.$19.00 with the hardware
