bkabina Posted January 18, 2004 Report Posted January 18, 2004 What would the pro's and con's be for the yz 250 reed mod.I heard abunch of people are getting it but nobody said about the goods and bads also how much does it cost? Quote
Patriot Racing Posted January 19, 2004 Report Posted January 19, 2004 The goods- increased reed area. More flow = more go The bads- Cost- not only is it quite expensive to fab and graft on new reed boxes, but you really need the rest of the cylinder set-up to take advantage of the bigger reeds. The transfers require substantial amount of work to use the available flow. Problem is you start to get close to what an aftermarket cylinder set costs that comes with those reeds already!!! Quote
bkabina Posted January 19, 2004 Author Report Posted January 19, 2004 So,I guess the smarter thing to do would be to buy aftermarket cylinders,And you would get more transfer area than you could get from substantialy reworking the stock cylinders.Am I on the right path? Quote
