I am hopeing you guys can help me out.
I studded a worn set of maxxis rear razrs with 7 studs per nobby
and 3 studs per nobby on the side nobbs it hooks allright
Im runnin dunlop stock tires in the front with 3 studs down the center nobbs
and 2 studs in the rest of the nobbs
. It shakes crazy like 5-6 gear cant top out because of it
Im guessn the tires are out of balenced
is there any way I can fix this or tame it a little ?
Im using Using 5/8" Gold wannabe koldkutters
mounted on stock rims
thanks
i woud put it on an old "bubble balancer"
or go buy a cheap one
those are the tripod style wheel balancers taht you set teh wheel on top of and line up the bubble style level in teh center of it
then use soms stick on wheel wheights for race car slicks
check out someplace like jc whitney for a cheapy blancer like that one or a plce like harbor freight
If you placed the studs evenly all the way around the tread it seems to me that it shouldn't cause a problem. Could it possibly be something else like the tire's bead not seating all the way??? May something inside the tire itself.....water or a chunk of dirt?
I guarantee the slime is your problem...If you don't run the shee long enough after you put the slime in, then it hardens on one side of the tire....You have to ride around for the slime to evenly spread out.....I've never had a balancing problem from studding...A good way to balance is too fill a tub of water and put the tire in it. The heavier side will face down......
Agreed with Banchetta, 16oz. of slime settled in one spot would cause any wheel to be unbalanced. With that much slime I bet its hard to even hold on!! :o
16 ounces of slime is your problem, that is a lot to be using in any situation. You need to get that stuff out of there and patch the tire or plug it.
erbilabuc Posted on Jan 13 2004, 03:18 AM
16 oz of slime is recommended on the bottle.
I brought the tires in the house to thau out.
I ll try them later.
Klotz Posted on Jan 13 2004, 02:24 AM
try one stud per knob..thats what i did i was doing wheelies
1 stud per nobby I tried that last year it didnt
do much . I can see doin that on a set of chin shen tires
theres more nobbys than razrs.
Stuff Posted on Jan 12 2004, 11:03 PM
yeh it was a little crazy to hold on to.
thanks fellas
You should have lined your tires with old carpet or duct tape & ran tubes. Ice picks in the back are better then kold kutters also more hook less BS & youcan make a nice even pattern.
Indeed it may be the recommended amount. However, if it hardens in one spot, than you have about 10 ounces at least on ONE side of the tire. Not a good thing..... Guaranteed that is the balancing problem.....
