Bigairee Posted January 11, 2004 Report Posted January 11, 2004 This sucks. Now I know why compression went down in 1 cylinder. I looked on the pistons and couldn't find anything referring to their size. Would this mean that they are stock. I will be carrying them to the machine shop this week so I will know for sure then but I wanted a general idea. Quote
locogato11283 Posted January 11, 2004 Report Posted January 11, 2004 damn i would say that its time for a rebuild. that piston looks horrible. what the f*ck happened to it? that cant have just worn naturally. Quote
XTShee Posted January 11, 2004 Report Posted January 11, 2004 isn't the size normally stamped on the top of the piston? If you buff the carbon off you should be able to see it Quote
. Posted January 12, 2004 Report Posted January 12, 2004 That was on the exhaust side right? Same thing happened to me, mine looks a lot lot worse. I'm guessing you caught a ring in the exhaust port. Looks like you ran it that way for a little bit with the blow by. Just a little tip. Dont buy a new piston set from NBS distributing, formerly known as Recreation Unlimited. They completely F'd up my order and gave me the runaround and 6 weeks later I gave up and got a cylinder setup from on here. Quote
Bigairee Posted January 12, 2004 Author Report Posted January 12, 2004 I did run it that way for a while. I noticed the compression loss about 8-10 engine hours ago. went from 145 to 120 but ran good. It finally dropped to 100 and I figured it was time to tear it apart. Didn't expect to see the ring gone. Quote
boonman Posted January 12, 2004 Report Posted January 12, 2004 I used to get my top end sets from Moto-Man.com. Always had good luck. Never had a problem. 2 days later, I get my shit. Sucks that it happend to ya, but get the pistons before they bore it. They should be able to set everything properly. Quote
