rtg_61184 Posted October 15, 2025 Report Posted October 15, 2025 Do these arms look like they are installed correctly or should that top arm be flipped 180deg? Also what are some good things to measure and adjust while I have it up there and all apart? Quote
JerzOutlaw350 Posted October 16, 2025 Report Posted October 16, 2025 The way they look in the picture they look like they are installed correctly. With the design of the upper A-arms, if you can stand over each side and look down at the upper heim joint it should either match up or sit slightly back ( about 1/4”) to the lower ball joint. ** I also think that you have to install the stock dust caps from the upper and lower OEM A-arms onto these A-arms. 1 Quote
rtg_61184 Posted October 17, 2025 Author Report Posted October 17, 2025 Thanks for the input! Looking down at it, the top heim is definitely further back towards the rear, by more than a 1/4" - more like 1/2"-3/4" Quote
rtg_61184 Posted October 22, 2025 Author Report Posted October 22, 2025 *update Talked to Jed at roll design and it is correct. Also found out they are not roll design arms but instead a very close copy. Oh well I'm still gonna rock them, I was young and dumb way back when I bought em off someone here on bansheehq. It's a trip to logon here and see my post and comments from 20 years ago Quote
