you have to remove the coolant lines, remove the one that goes to the water pump first that will drain most of the coolant. I also remove the carbs and intakes when I remove cylinders. If you remove the intakes plug the openings with rags just so nothing can fall into the bottom end. Also after you pull the jugs cover the open crankcase to keep out dirt an so no small parts can acidently fall in.
  • 2 weeks later...
