racin69z Posted December 30, 2024 Report Posted December 30, 2024 Is there a specification for end play on the transmission shafts? I have around .030" on each shaft. Seems a little excessive. Can't find anything in the Yamaha service manual. Quote
racin69z Posted December 30, 2024 Author Report Posted December 30, 2024 I got to thinking about it. I think when I bolt the clutch hub on it will pull that shaft into the larger bearing. And the same for the sprocket. Making no endplay. Quote
kawa110 Posted December 30, 2024 Report Posted December 30, 2024 Correct. Need thrust washer behind the clutch basket and one inside of it. Sent from my iPhone using Tapatalk Quote
