adamsmw Posted January 6, 2004 Report Posted January 6, 2004 I have been running through some coolant lately on 03 Banshee. I decided to do a compression test and discovered each cylinder is at about 95-100 psi. I know this is way lower than it should be at an elevation of around 800 ft. Thinking I overheated. I pulled the head off and changed the head gasket. The old gasket didnt show any signs of leaking and the cylinders didnt look scored, the top of the pistons looked good. Anyways a compression test with a new gasket showed the same results. Come to find out when the K&N filter was installed, it wasnt rejetted. What would the possible problem be? Quote
ruff_rida69 Posted January 6, 2004 Report Posted January 6, 2004 you probley just need new rings. Quote
flea49 Posted January 6, 2004 Report Posted January 6, 2004 WITH THE HEAD OFF PUSH THE PISTON TO THE BOTTEM OF THE CYLINDER IF THERE IS SLOP YOU NEED A BORE THE CLEARENCE FROM WALL TO PISTON IS.003 Quote
Justintoxicated Posted January 6, 2004 Report Posted January 6, 2004 you were running it lean if it was not re-jetted, which probably heated it up more than it should have and helped cause this problem. I would bore it if the clearance is off, get some new pistons and rings, another new gasket set and some new jets for your carbs. Do WOT testing untill you get it right. Are you sure the compression tester is accurate? Quote
adamsmw Posted January 8, 2004 Author Report Posted January 8, 2004 Thanks for the good info. How do I measure the clearance of the piston? The only gauges I have are to wide to measure on a curved surface. I am pretty sure the tester was accurate. Quote
