Engine casing hosing
Machoman
I cant figure out how to delete posts but i had it on the right spot.. the carb. But i am going to open up crank case because i did my oil change and topped coolant. But the coolant leaked into the oil and now milk gray.. and radiator is empty. Hopefully its not a crack
That’s just a vent hose. I just run it forward and down and zip tie to the frame. Do not run that to the carbs.
If you have coolant in your oil, your water pump seal is bad.
Thanks for the reply, the seal prob does need replacing I just got this thing from someone who also just had gotten it from someone. Lol
