i just re read your sig and i am gonna have to call bs on what you got goin on. why would you run 2 diferent size sets of domes. you either have a big bore and need the domes or from what i understand you dont becuase you have no big bore and if you did have a big bore i would think you would need to run big bore domes all the time and switching your domes out every time you decide its a big bore or not does not make sence. i dont know maybe i misunderstand what you've written. l8ter
yes i use big bore domes cuz my pison is big
i can use both of them
plus alba action recomeneded that i use big bore dome
the thing is whats the best comp for drag racing
i dont want 2 lose top end
hmmm i never herd of runnin big bore domes on a bike thats only been bored 80 over i know 2 bikes that are and they dont run big bore domes but if it works it works. i guess u would be okay runnin the higher comp as long as you use race gas and have your crank welded i know that once you go to high on your compression you can actually loose power becuase the engine cant rev out properly but i guess if it runns better with the highest comp you can get then run it maybe you should try out a set of like 19's if you want a lil mo power but with 230 lbs i would worry bout my crank trashin itself cuz the comp is to high... could be wrong there are more educated ppl on here then me tho so maybe some one else could answer your question.
