I still need A Gas Tank, Motor (Running), Motor Mounts, Carbs, Intakes, Exhaust (aftermarket), and Oversize clamp style (1 1/8"?) Handlebars. Thanks - JT
i have a whole stock carb setup, all you need to do is put the reeds in one end, and airfilters in the other, and a crossover tube, the insides need cleaning thou
I have a stock tank w/o the pit cock, both complete stock carbs w/ intake boots and the boost bottle to go with it, and I also got the motor mounts with it too. the only problem is the throttle cable is beat up, and needs to be replaced, and it comes with no jets. So send a pm it your interested. I'll see if I can get pics.
Ive got a motor that for $2k (shipped) you could pry from my hands. It's .030 zero hours, play/race port, cool head with our domes (160 psi), T/W, TZ brg, new OEM basket, barnet spgs, 460 plates, shift shaft, shift star mod, timing plate, v-force, billet 1 piece intake (your choice 26-28mm or 34-36mm carbs).....just add carbs, pipes, sprocket, kicker, shifter and youve got 60+ hp at your finger tips.
