Shifting issue
Hey guys, got an issue. I'm working on a bike for a friend. Mostly stock 97. The shift shaft is coming off the shift star and getting stuck. I already pulled it apart once and adjusted the actuator, but it did it again.
Not sure how to diagnose the issue. Does the clutch cover hold the arm in place? If so, not sure how it's moving side to side. Any help is appreciated
Yes the side cover holds the shaft "in" The pivot on the pawl that grabs the star is certainly loose and worn out. The fix is to buy a new shift shaft. F.A.S.T Racing sells a new OEM modded one that they grind a bit for more throw and tweak the end in for better contact with the star.
