Fr33zypop Posted May 22, 2021 Report Posted May 22, 2021 I didn’t install the case saver on my banshee and have found it’s leaking quite a bit. It’s plastic but not sure if this is normal or if the messed it up somehow. Not sure if it needs a gasket or some rtv to help seal it up. Sent from my iPhone using Tapatalk Quote
Metal_man_Rob Posted June 1, 2021 Report Posted June 1, 2021 I didn’t install the case saver on my banshee and have found it’s leaking quite a bit. It’s plastic but not sure if this is normal or if the messed it up somehow. Not sure if it needs a gasket or some rtv to help seal it up. Sent from my iPhone using TapatalkBehind the case saver is a “neutral switch” unless the case saver doubles as a neutral switch cover. It is a plastic triangle, isn’t used for anything and has an oring that will leak. They also crack easily, I guess.Drain the gear oil and remove the case saver. Put in a new oil seal. Sent from my iPhone using Tapatalk Quote
