itsmyforte Posted December 15, 2003 Report Posted December 15, 2003 anyone know where a wiring diagram is posted for the banshee? have a 93, but am putting a full 97 wiring, cdi, coil, regulator....blah, blah, blah. need to get a photocopy of the diagram asap. ordered a manual but who knows how long it will be before i get it. gotta get this fixed, its for a christmas present! Quote
itsmyforte Posted December 15, 2003 Author Report Posted December 15, 2003 that should work, do u know what year its from? from information i've gathered it appears they are all the same except for an extra wire on 94-up. i assume the whole 97 kit i purchased will connect to a 93 stator. oh well if not i be cuttin wires, fuk it! btw, THANK YOU! Quote
BenBB Posted December 15, 2003 Report Posted December 15, 2003 I dunno for sure what years it covers, it came out of my Clymer. It's accurate for my '96, but you're right the later years had an extra wire coming out of the CDI (purple I think). Not sure what it does, I got a Dyna CDI for mine that had that extra wire, I just taped it off and it runs fine...hope this helps. Quote
itsmyforte Posted December 16, 2003 Author Report Posted December 16, 2003 thanks for the additional info, makes things much easier when you know more about the products your installing. Quote
bradrs Posted January 6, 2004 Report Posted January 6, 2004 I dunno for sure what years it covers, it came out of my Clymer. It's accurate for my '96, but you're right the later years had an extra wire coming out of the CDI (purple I think). Not sure what it does, I got a Dyna CDI for mine that had that extra wire, I just taped it off and it runs fine...hope this helps. The extra wire on the 97- is connected to the parking brake switch, which is used to provide a much lower rev limit with the parking brake on. One the 97- Dyna ignition, this is used as the input to the programmable launch limiter. This wire is not installed on the pre 97 Dyna ignitions, since there is not parking brake switch on them. Brad Quote
