Ownartifact Posted March 28, 2021 Report Posted March 28, 2021 Ok I was sent a long rod wiseco piston problem is my crank is a oem style hot rod crank will the pistons work with my crank? Quote
375hp banshees Posted March 28, 2021 Report Posted March 28, 2021 Not if your cylinders are stock or not ported for it. Is the piston # the same as one you pulled out?How did you end up with those new pistons?Sent from my SM-A505U using Tapatalk Quote
