Ownartifact Posted February 11, 2021 Report Posted February 11, 2021 Is there anything special I have to do to put 392 athena cylinders on my bottom end I got a stock stroke hot rod crank in the bottom end Quote
Keno Posted February 11, 2021 Report Posted February 11, 2021 Don't get Athena cylinders. Driveline are better http://www.drivelineperformance.com You will have to call them or email them to order the cylinders. Another option is to send your stock cylinders to Redline Racing to be ported. Stock ported are producing same or better than the Athena's these days.http://redlineracing.biz/services/porting/But to answer your question, 392 kits typically are meant for stock cranks, so just bolt it on and check squish. Quote
Ownartifact Posted February 11, 2021 Author Report Posted February 11, 2021 I have aftermarket crank it’s just oem stroke Quote
Keno Posted February 11, 2021 Report Posted February 11, 2021 Yeah, by oem I meant stock stroke 110mm rod. Quote
Ownartifact Posted February 14, 2021 Author Report Posted February 14, 2021 Oh ok so what kind of crank would I need and I heard if you get anything bigger than a 392 kit you got to bore the bottom end is that true Quote
