well it depends on how cold you ride it in , i see your from alaska , if were talkin like 10 degree weather, maybe you'll have to warm up your jugs with a blow touch like the ice racers do
Did you remove the slides in the carbs - they might be in backwards ( left in right right in left) 99rr
thats what happened, I took it appart last night and I had the tops of the carbs switched.
I switched them back, turned the idle back down and it runs like a champ again.
thanks a lot for your help guys.
is it possible he had his gas and oil mixed a little off. maybe hes got too much oil and thats what is causing the oil on the plug?? just a thought.
SHOULD I CHANGE THE OIL:GAS MIX IN THE WINTER?
I WAS RUNNING 24:1 IN THE SUMMER, BUT SHOULD YOU LEAN IT OUT IN THE COLD?
THANKS
