Bansheeforlife13 Posted January 21, 2021 Report Posted January 21, 2021 (edited) Would like to know what everyone is using for a battery to power their limiter box? Is the drl-300cdi the proper box to use on a banshee? Any info would be great! Thank you Edited January 21, 2021 by Bansheeforlife13 Quote
375hp banshees Posted January 21, 2021 Report Posted January 21, 2021 Haven't hooked mine up yet , but I believe Everybody is just using a 9 V Quote
375hp banshees Posted January 21, 2021 Report Posted January 21, 2021 Here... the dip switch ( Not to be confused with Skeeter ...that's a dipshit... And nothing will get done with one of those) settings for 2 cyl, 2stroke are there too!Run b+ through clutch switch and ground to 9v batt AND to a good frame groundSent from my SM-A505U using Tapatalk Quote
Bansheeforlife13 Posted January 22, 2021 Author Report Posted January 22, 2021 (edited) Thank you! I was under the understanding that it needed 12v to run the box. The correct box for a banshee is the DRL-300 cdi right? Edited January 22, 2021 by Bansheeforlife13 Quote
375hp banshees Posted January 22, 2021 Report Posted January 22, 2021 Yes, if you set dip switches as aboveSent from my SM-A505U using Tapatalk Quote
Bansheeforlife13 Posted January 22, 2021 Author Report Posted January 22, 2021 Ok thank you very much! It is appreciated! Quote
