Ecolandscaping17 Posted October 6, 2020 Report Posted October 6, 2020 No spark. Just bought bike. Had it running and now it has no spark. Checked ohms on stator, pickup, coil primary and seconday, wires and caps. ALL.TEST GOOD. Continuity in on/off/light switch is good....(although it beeps continuity on OFF. Dont think this should effect spark as long as i have it on OFF, aka, the new ON.) Key switch has good continuity. Has a tors delete. Everything unplugged and/or cut. BRAND NEW. I replaced or replaced with: Flywheel, Stator, wire harness, key switch, cdi box stage 2 , voltage regulator, keyway, dynatek coil Only thing i didnt test was cdi box because i couldnt find anything on that. Quote
hoppedupandcutdown Posted October 6, 2020 Report Posted October 6, 2020 Key switch needs continuity to run. Thumb switch can not have continuity to run. OFF grounds the black to the black/white. Borrow a good known CDI and try that. (no way to test one) Quote
grantevans713 Posted October 7, 2020 Report Posted October 7, 2020 If you replaced OEM stators and flywheels, I hope you replaced with more OEM. The cheap stuff could be causing a new problem. Quote
fixitrod Posted October 11, 2020 Report Posted October 11, 2020 Did you try a new stator or test it only? I've tested stators that tested good and were not. If you haven't tried one see if a friend will let you pull theirs to try it. But, your switch comment is a bit confusing. You do not want the run switch to "beep" continuity to negative in the run position. Quote
