Ecolandscaping17
Everything posted by Ecolandscaping17
  1. No spark. Just bought bike. Had it running and now it has no spark. Checked ohms on stator, pickup, coil primary and seconday, wires and caps. ALL.TEST GOOD. Continuity in on/off/light switch is good....(although it beeps continuity on OFF. Dont think this should effect spark as long as i have it on OFF, aka, the new ON.) Key switch has good continuity. Has a tors delete. Everything unplugged and/or cut. BRAND NEW. I replaced or replaced with: Flywheel, Stator, wire harness, key switch, cdi box stage 2 , voltage regulator, keyway, dynatek coil Only thing i didnt test was cdi box because i couldnt find anything on that.
  2. Pickup gap is good. Yeah not a stock cdi box obviously, but brand new. Ill have to get a stock cdi box. This thing is a nightmare.
  3. The stator is not oem, but ohms check out perfect. Coil is grounded/boltes to frame. As far as cutting back wires, I did not. I would say theyre about 8 inches long. And the cdi box, how do i know if it is working or not? How do you test a cdi box.
  4. No spark. Just bought bike Checked ohms on stator, pickup, coil primary and seconday, wires and caps. ALL.TEST GOOD. Continuity in on/off/light switch is good....(although it beeps continuity on OFF. Dont think this should effect spark as long as i have it on OFF, aka, the new ON.) Key switch has good continuity. Has a tors delete. Everything unplugged and/or cut. BRAND NEW. I replaced or replaced with: Flywheel, Stator, wire harness, key switch, cdi box stage 2 , voltage regulator, keyway, dynatek coil Only thing i didnt test was cdi box because i couldnt find anything on that.
