Delly Posted September 27, 2020 Report Posted September 27, 2020 Hey guys is there suppose to be play in this shaft? I installed the basket and clutch hub and torqued the shaft nut down, but there’s play back and fourth, the bike had a Hinson basket and the pucks are good, there’s no movement there it’s wiggle back and fourth movement like pushing in on the shaft and pulling out. That normal? Before I took the bike apart there was no problems with shifting etc.. thanks for any help.. Quote
Tedder Posted September 27, 2020 Report Posted September 27, 2020 The large primary gear and outer basket assembly with the two thrush plates (thick washers) on each side will have in and out movement . The inner clutch hub doesn't move in and out once the nut is run down. Quote
Delly Posted September 28, 2020 Author Report Posted September 28, 2020 Yes correct ,ok just wanted to make sure there wasnt a issue in the trans. Thank you Quote
