Bobbys_world07 Posted September 9, 2020 Report Posted September 9, 2020 I’ve just bought a 05 shee a few months back and decide to do a restore and to get me more power..now I’ve have every thing back together and motor in I did a compression test. My setup is new stock cylinders & bore on a 7 mil with 22 cc domes. Planing to run 110 octane.. I bought a otc compression tester and Tested both cylinders witch they made 120.. I did my Squelch test and they were both Consistent with a .50 and .53.. is it a faulty reading with my tester? I’ve read where the long hoses can give you miss reading. This is my first 2stroke build so I’m a little wet still, so some input would be sweeet. Quote
375hp banshees Posted September 9, 2020 Report Posted September 9, 2020 Elevation? what did your porter say? nich cylinders or genuine OEM Yamaha? Sent from my SM-A505U using Tapatalk Quote
Bobbys_world07 Posted September 9, 2020 Author Report Posted September 9, 2020 On 1/11/2009 at 1:10 PM, BklynLOD said: I have the same setup, 22cc domes, +4 timing and cant get why I'm running 165 - 170 compression. Tested it with like 5 different compression testers and got between 165 and 170 between all of them. I have to run race gas. The weird thing is I ran 93 on it before I realized my compression was so hi and didn't blow the engine. While testeing we remove spark plug. Open the throttle wide opne and kick about 15 times. I live in Florida and they are after market.. bought from Kevin Herr Quote
375hp banshees Posted September 9, 2020 Report Posted September 9, 2020 What did kevin say, what brand aftermarket?What kind of port job?Sent from my SM-A505U using Tapatalk Quote
Bobbys_world07 Posted September 9, 2020 Author Report Posted September 9, 2020 He didn’t just that it’s what he uses Because I was wanting to run yamaha’s but he said after porting they clean up and hold good up and they are proven witch I trust him.. I have a drag play port tho! Quote
Bobbys_world07 Posted September 10, 2020 Author Report Posted September 10, 2020 So I bought another tester and I was able to get 150psi Quote
375hp banshees Posted September 10, 2020 Report Posted September 10, 2020 Thats sounds right Sent from my SM-A505U using Tapatalk Quote
Bobbys_world07 Posted September 10, 2020 Author Report Posted September 10, 2020 Sweet.. now for gear oil.. any recommend’s I have some bel ray 80w-90 gearsaver. Quote
kawa110 Posted September 10, 2020 Report Posted September 10, 2020 Bel ray goodSent from my iPhone using Tapatalk Quote
