JTPoulsen Posted July 18, 2020 Report Posted July 18, 2020 Bottom end tranny rebuild. Questions and parts and website to order good kits Quote
JTPoulsen Posted July 18, 2020 Author Report Posted July 18, 2020 Stuck in 3rd an fourth.. I think. Runs fine still drives just can't get out of gears. Any common reasons why. Or what would cause it? Quote
JTPoulsen Posted July 18, 2020 Author Report Posted July 18, 2020 I rebuilt my motor myself, its probably got less that 40hrs on it since then.. An I could have sworn I put new bearings all the way through.. Bit I didn't replace shift drum, trans gears, shift forks, shifting shaft or the shifting star mechanism. It's just odd to me it shifted like a dream and I played in the rain one day and bam it's stuck in gears. I'm hoping I can fix it with only taking off side cover, but I feel I'm going to have to split the case. Quote
375hp banshees Posted July 18, 2020 Report Posted July 18, 2020 Pull cover & inspect . If nothing loose, broken/ bent or out of adjustment, could have bent a fork & need to split Quote
Banshee508 Posted July 18, 2020 Report Posted July 18, 2020 Mine did that one day an it was the shift shaft theres a little spring that got hung up Quote
JTPoulsen Posted July 20, 2020 Author Report Posted July 20, 2020 You talking about on top of the motor or the one going from the shifter to the other side? An did you have to split the case. Quote
