Hello... I have an 03 banshee that has a small leak coming from the clutch actuator arm (where the clutch cable hangs on to right below the left carburator)... so I want to replace that seal but I can not remove the clutch arm itself. I remove the bolt and bracket that holds it down but I can not pull up the clutch arm... I’m I missing something else to pull out that clutch arm? I appreciate any help you guys can give!
