Hello everybody names Rob, go by Bullseye. Just purchased my first ATV yesterday. Previous owner didn't tell me much besides it needing the carbs tuned and the clutch engages very slow near lever being all the way out. Doesn't stall if i engage it. He didnt mention the mods it has and was wondering you guys can spot out aftermarket parts on it. I see the pipes are toomey. Popular I see. Also previous owner wrote some stuff under seat about the jetting i believe. Its spits out oil/fuel from right tip and just a few min ago it kind of stopped working. Only left was blowing.
https://imgur.com/a/i49JE7y#SYkA4ke
Edited by SocalBullseye
Looks like pods and pipes are the only mods. Very clean quad though. You need to do a leak down test and a  compression test first off to determine it's wear factor. The right side spitting oil is a sign of the right crank seal failing.
  • Like 1
This statement still stands.
Raw fuel out the pipe means that side isn't firing. Pull the pipe, dump out fuel, pull plugs and kick for a while, install new plugs.
